Electrical.
I'm absolutely no expert on this, but it's just a relay. If you jumped 2 to 4 and it started, there is only 1 of two things preventing it from starting with your relay in. 1) the relay is bad, or 2) the relay is not getting a signal, or ground.
See if you have ground on pin 1
If you have ground at pin 1 - check for a 12v at pin 3 with the ignition on.
If you have a signal at pin 3 with the ignition on, you have a bad relay
If you have no signal at pin 3, you need to find out why...
^^^^ What Jon said. The intake tube is the big black tube running from your air filter box. Inspect it. Squeeze it and see. If it is cracked you can wrap in duct tape temporarily (or permanently if you are a :hillbilly:) and get a new tube.
This is a fairly common problem seen. I think it is because reverse puts a different torque on the engine or something. I think Jon has explained it somewhere before.
Not a bad idea to go ahead and check all of your vacuum hoses while you care looking at this. Make sure they are all connected and in good condition.
