Baselining my 3FE has been easy to do thanks to Mr. JonHeld's guidance and inputs (thx Jon). Continuing to do a few things beyond what's listed there but that was an excellent way to start learning and improving my '92 picked up already two years ago. Time flies.....
As far as something similar on the electrical side (preventative maintenance), there doesn't seem to be any such check list. Things I'm looking to do relatively soon are listed below, please let me know what I'm missing:
--t
- Replace all ground wires with similar or larger gauge. Az is low humidity, have some welding 4ga and might tin the ends before adding terminals and heat shrink, will match gauge and do similar with other wires - let me know if I'm an idiot.
- Replace OEM alternator with larger 90 amp one (preferably one rewound for even greater amperage - go Tundra?) - needs new bracket apparently. OEM alternator starting to show signs of age, just getting in front of this.
- Rebuild existing alternator and put it on a shelf, ready to go. Why? Never done it, seems easy, good project to learn from and will be good to have a healthy backup.
- Under hood fuse box, replace EFI relay and rewire fuse box leads (I've got at least a few brittle wires in there from the little inspection I've done). EFI relays, any reason NOT to pick up "cheapies" from AutoZone/Napa or is this another "GO OEM!" item?
- Consider EFI relay relocation? Jury seems out on whether this is necessary or not, getting away from engine heat being the goal but doesn't sound like it's absolutely necessary. I have definitely experienced the HARD START after a long day of wheeling on a pretty hot day, wasn't fun. Thought for sure I was going to wind up stranded as I didn't know anything about EFIs and my options at that time.
- Clean up positive runs to the battery (thread already exists, not going fancy but do have some room for improvement).
- Replace fusible links - is there an UPGRADE here (larger gauge?) or just go with OEM replacements?
--t
