Ok, So I finally have some free time and extra coin to start putting work back into the rig. I have started planning on electrical stuff. As it stands right now I have a 12voltguy.com dual battery and winch kit. I haven’t installed it yet because life. I’m ready to install that, and add the second battery. So I’m trying to figure out a parts list. I have everything I need to the dual batteries, I need help making a shopping list for accessories, and some input for ideas that I have. Here goes.
A 12 position fuse box similar to THIS ONE. I only have seven things on my list that will need fuses at this time. They are:
Front light-on rack
side lights-on rack (work lamps for campsites and late night travels nothing too bright)
rear lights-on rack (same as side lights)
Radio- I plan to run my in-dash stereo off the secondary battery. I like to have music while I’m camping. I figure this will allow me to do that without worrying about draining my start battery.
CB- Gonna need a fuse anyway
OBA- York 210 clutch. What’s the amperage on these? I don’t even know what size fuse to use for that.
12v plugs/switches- a always hot 12v plug and USB hub up front, on the back to the console for the 2nd row, and one in the cargo area. This will also power the LED’s for the switches and apply acc signal to the radio (talk about that later)
I figure I need 3 relays for now. One for each set of lights. Maybe a 4th depending on the York clutch's draw. I can always add more.
Switches. I’ll need 5. One for each of the lights, one for the OBA and one for the ACC switch. This last switch I’m calling an ACC. It basically sends a signal to the ACC wire in the stereo to kick it on. The vehicles ACC will also be attached to the stereo so that it works normally, but with the switch I can kick it on without the key being in the ignition, and the radio is drawing from the 2nd battery.
Does anyone see any problems with these ideas? Any room for improvement? What are some must have electrical goodies I’m leaving out? I figure extra positions on the fuse block will allow me to expand in the future.
Front light-on rack
