Electrical Qs - Let's start with Hazards.
So nothing means that the both the front and rear bulbs don't light up, even weakly?
If so, then there is a bad / broken contact in the switch or both F and R wires on the R are broken / bad. More likely one bad contact inside the switch than two bad wires simultaneously. Since the L side works, then there is power at the switch. It just doesn't make it to the R side.
Correct, no weak light up just nothing.
I think I over squeezed the metal case putting everything back together, which caused the current failure (nothing works, lights, blinks). Then trying to fix it I lost the ball bearing so Ill pick up a new one tomorrow and go through this again on Tuesday.
Thanks Pin and Big Red, even though I am not any closer to solving this thing, I am grateful you guys are acknowledging my misery. :cheers: If/when I get this fixed, I get to move past needs to wants so I've got that going for me.
I had similar issues with my hazards (worked occasionally, and linked to turn signals). pulled the switch and cleaned the terminals in the switch with dremel and contact cleaner. Be careful with the springs and ball bearing. I was amazed by the the analog design and clean internal condition of the 40 year old switch.
