Electrical Qs - Let's start with Hazards.
So my hazards work but only if my turn signal (left or right) is on.
My right turn signal is not working unless my hazards are on (it doesn't blink independently)
My left turn signal works but the left turn signal indicatior only blinks when the hazards are on.
I love these old things
Any suggestion on where to start?
OK
The hazards get their power from a different fuse than the turn signals fuse, so check the fuses first. If it is not the fuse, chances are that the hazard switch needs rebuilding by cleaning all the contacts and reassembling.
The high beams are a separate issue. Chances are that the Hi/Lo switch needs replacing or rebuilding.
Thanks, I'll work on cleaning all the contacts tomorrow. It is not the fuse - all new as of today.
Had the same issue. It'll act possessed. It's oxidized/dirty contacts. Fuse block, harness terminals, switch poles...Clean up everything and you'll be back in business. Obviously, make sure you've got clean ground all around too.
I got in there and cleaned everything. Grounds look surprisingly good. I may have identified the problem with the right turn signal (will know tomorrow once I solder the wire)and I was able to fix the horn.
Still having an issue with the hazards only working if either turn signal is engaged. To me this indicates that the hazard is wired to the incorrect fuse. Anyone have other ideas?
This vehicle is new to me and there has been a good amount of electrical done but I am not sure how with existing wiring harness the Hazards could be pulling power through the turn and not independently. But,....I am a rookie.
Thanks Pin Head. On a related note - are there any tricks to getting wires & crimps removed from connectors? I am using a tiny screw driver but can't feel a release anywhere.
Thanks!
With pic
Soldering the previous mend didn't fix either the hazard issue or right turn signal issue :bang::bang::bang:
Have you checked to make sure all your bulbs work.
You cleaned up the grounds at your front and rear turn indicator assemblies right?
Curt makes a good point, make sure they all work and the sockets are clean.
Like I said, I had the said same odd turn indicator/hazzard behavior and it was just poor connections. It will do some weird sh*t.
I don't know the difference between a 76 and my 81, but mine works similar in that the hazards only work when a turn signal is engaged (but turn signals work without the hazards being on). Mine is due to the switch relay. The original relay had a three prong connector and two separate switches inside. One of the switches went bad, so my turn signals stopped working, but the hazards worked. I rewired so that the turn signals use the hazard switch. The only replacement switches I could find use one switch and work similarly.
Bulbs work at both the signal and dash.
Left turn signal works.
Right turn signal does not work -neither dash bulb nor at light (unless hazards engaged).
Hazards work if switched on and either right or left signal is engaged (if I turn on the the hazards without engaging either turn signal nothing happens)
I am digging back into the hazard switch to see if I missed anything the first time.
Put the hazard back together and now everything is shot The triangle shaped pieces are interchangeable, correct?
anyone happen to know the size of ball bearing under the hazard assembly?
By work I mean operated as it should. For example the the left turn signal blinked when engaged.
By not work I meant nothing happens. I.e. TuRn on right turn signal and nothin :)
