Electrical problems again
Tucson, AZ
So I've been having problems lately with the charging system on my 69 FJ40. It was fine a year ago or so but would always blow the turn signal fuse which also is in conjunction with the alt. I replaced the voltage regulator and that fixed the problem but now after changing it 2 more times under warenty the amps are very erratic espically with the headlights on. Some days it's good but last night it would just randomly shoot up. I could even hold the engine at a certain rpm and the amp meeter would literally just pulsate from -30 to 30 amps and the head lights would pulsate too.
So I've replaced the alt. ground, checked the battery ground, checked the vr ground. Still nothing. I had Orileys bench test the alt. and they said it's fine but I've heard that auto parts stores sometimes aren't the best at testing these things. But I'm really stumped at why this thing seems to keep frying the voltage regulators. Any help is much appreciated
Could there be a wire that has broken/worn through isolation and it hits ground every now and then? Most likely somewhere where the wire goes through the sheetmetal.
Im
I'm gonna look into that when I get home from work. I would think it would blow the fuse though if it's shorting out.
If the wire has fuse, it would most likely blow, but it might be in wire before fuse or in wire that doesnt have one. Might want to start your search from alternator and voltageregulator wirings?
Im not sure how shorted battery would act like, but i think it might be one possibility too?
coolerman sells the fusible links if you happen to need one, always a good idea to get one for a spare. . .
The 1969 FJ40 did not come from the factory with a fusible link. I DO sell a kit to add one however.
Adding this will not fix your problem, but may help prevent a harness fire should you ever have a short in the large White wire between the battery and the Amp Meter.
The Red/White wire on the regulator is the sense wire. It monitors the voltage at the fuse panel and uses that to control the field current in the alternator which controls how much current the alternator puts out. A short in that wire would of course blow the turn signal/regulator fuse.
However, so would a short anywhere in the turn signal circuit.
From your symptoms I would check the following: There is a ground wire (White/Black) that runs between the regulator and the alternator. This is a critical ground. It runs from the E terminal on the regulator (This point is also grounded to the firewall ) to the top terminal on the three pin alternator connector. It's purpose is to ensure that the regulator and alternator are at the same ground level. If this wire is disconnected, the regulator will function erratically. Take this loose, clean it good and also clean where it touches the firewall. The alternator also grounds through it's mounting brackets.
If that is good then you may have yet another bad regulator. The cheap ones are just that, CHEAP! Toyota may still have the OEM regualtor available. Check with CDan or Beno to see.
Last, clean the fuse block clips for the turn signal fuse, clean the amp meter connections, clean the battery terminals and frame grounds.
It runs with the White/Green wire from the alternator to the regulator E terminal. This is sort of hard to explain but here goes: At the regulator there is a ring terminal that goes under one of the regulator mounting bolts. This ring terminal has two wires going to it. One goes to the alternator and the other is the main cowl harness chassis ground. The regulator is grounded by this ring terminal through the mounting bolt. This point is the E terminal.
Here's pics
The alternator harness you have is not OEM but it does appear to have the ground wire in place. There are only two wires to the alternator plug and you have both.
