Electrical problems again
Correct. There should not be a wire in the position.
Idk then because this it the 3rd vr and spector lists the oem as discontinued and they sell a aftermarket one that can't be much different than the one from Oreileys can it? And the battery is brand new. I've check pretty much every ground that matters as far as I know. I'm thinking alternator.
My dad tested the car and pretty much seemed like it was the alternator, Auto Zone said bad battery. Then O'Reillys said bad voltage regulator but then we got a warenty on the battery from them and put the new one on its the same story.
So, I know nothing...
Having said that... His alternator says "regulated alternator"... Does he really need a voltage regulator with this alternator?
Dozing off again now...
I think that tag is supposed to read "Recommend replacing the regulator when replacing the alternator", or something to that effect. An internally regulated alternator will not have the field connection which that one does.
I have a similar issue with mine. Trying to diagnose this issue. New to forum, Thanks for the thread. This will help isolate the headache. I will get back with you when I figure it out. Mine is a barn find that sat in FL for a long time. only 3700 miles and all #s match. a LOT of OEM on this, so I don't want to sway too far from center.
So in the end I ended up hunting down a internally regulated alternator from a 60 series I believe and getting rid of the external voltage regulator all together. I could’ve had a different problem that I never found being that my truck has or had a ton of electrical grimlins, but I’ve heard of the old external regulators being so finikey even when they are new and as I’ve said above I’ve gone through several of them with poor results. This might not be the fix for you or anyone else reading this, but my internally regulated setup is solid and has given me no problems aside from getting it rebuilt earlier this year. I will say it was almost impossible to track down the 80’s alternator I used so a more viable option would to just modify your bracket to use a GM alternator and that opens up a ton of doors.
Again this is just what I ended up doing you might have a simple issue that can be a resolved without all that. Good luck with it!
