Electric Hub replacement
Here is a stolen drawing from Toyota I have laying around of an electric hub
Alright, had a few minutes today to compare.
So spindles are actually the same length BUT the e-hub spindle lacks the tab groove for the 42030 thrust washer and the 42025 spindl lock washer. So... while you could bolt it all together, it wouldn't be too inspired to stay together. But new and use parts are readily available so non-issue there. We stock a Japanese replacement (FA60060) and a TG Chromoly spindle (FA140205).
Back view for posterity:
Next up is comparing the wheel hub's with pics :D
If anybody needs a set of used hubs and Aisin free wheels for 1990+ 70 series axels just send me a pm I still have a few sets available.
Joe
Hi Kurt,
I am currently running the conversion AVM hub setup on my HZJ77, which was done by PO. I was planning to rebuild the knuckles in the near future(get the rebuild parts from you) and assess the integrity of the converted hubs, I could take some pics of my setup if you wish.
Nick
Hi Kurt,
Nick
That would be great!
I kept the e spindle. Used an older 70 series hub. Swapped discs over. Reused the original hub nut but reduced its thickness. And reused the locking tab system incorporated into the slip ring. Don't have to worry about those double nuts and lock tabs. Was done over 15 years ago and no issues.
To delete the electric hub should the manual hub and spindle replacements should come from mini truck or FJ60 axles?
PU/4RNR (79-85) are the same as the 6x/7x (80-90)
No I only need the copper spring were you attach the carbons.
It´s missing a piece and beond saving:-(
The picture is not mine it's for reference only.
if anyone is switching to manual hub and spindle if u wouldnt mind selling me your wiring harness from the hub to main engine harnesss that would help me out alot
thanks
