Electric Connector Master
Arizona
I swapped in a new 80 series non abs master on my pickup however I need the 2 wire electric connector. Does anyone have an old 80 series harness I can grab this plug from or know a possible part number for one? I tried local Toyota parts dept and we could not find it. Here’s a pic of the master.
Thanks!
Thanks!
Ok check tomorrow. I might have one
You should be able to get the connector ID off the male end and search that online to find one. I have had good luck on my 80 series LS swap.
I looked at the plug socket on the master and do not see any ID numbers.
Might have to clean it up. Should be molded in. Wont be a part number, just an ID that can be used to reference it.
The master is brand new oem and there is no numbers on the electrical socket at all. The one from my 22RE harness is no help. :-(
If anyone has a minute and can pop their hood it looks like I just need the ID number off the plug :-) unless I get lucky and @05Tacorunner has one 👍
I am traveling for work until the 26th, but I can look when I get back. I'll either give you the part reference ID or an apology for the goose chase.
Pretty sure I have one on the shelf, I can check in the morning
have you contacted @richardlillard1 to see if there's a suitable harness part in what used to be Kevin's shop ?
