- Joined
- Nov 26, 2011
- Threads
- 5
- Messages
- 11
Does anyone know of anyone in California that does efi swaps?
Combat Chuck said:Any good Toyota shop can do it, but it's $$$$$$ because you'll have to swap you entire harness out.
The other parts can be had for a fair price, but it take a long time to disconnect and pull the donor harness, disconnect and pull the one it's replacing, install it, reconnect it, troubleshoot it. I as quoted 16 hours shop time on the wiring alone.
Not cheap at all but there are kits available. You would still need the upper plenum, injectors, rail and throttle body (at a minimum).
Pro Fuel Injection Kit #3(Naturally Aspirated)4Cyl
By the time you go through the effort of a 22r to 22re swap, why not spend the few extra dollars on a bigger engine? 3rz, 5vzfe or a Chevrolet LS v8?
GRM said:By the time you go through the effort of a 22r to 22re swap, why not spend the few extra dollars on a bigger engine? 3rz, 5vzfe or a Chevrolet LS v8?
