Not too many threads on this. In process of front end rebuild, pounded out the lower knuckle bearing race and found it was this eccentric job. The top race was standard, but the bearing was siezed on the steering arm and I had to score/chisel it off.
Running one eccentric would just probably cause odd loading, and not significant correction for any alignment. Also not sure which way it was installed.
So it appears someone was here before and I am not sure why. My plan is to use standard races and bearings, and I guess if caster needs to be adjusted use spring shims?
