eBay Wiring Harness
I have not done business with this vendor. I have not seen a Toyota FJ/BJ40 harness with plastic split loom like that, maybe the later ones did. Also it may be a good bit different from what you need since it is a diesel harness, is your truck a BJ?
For that much $$, I would get a generic aftermarket harness and use that. I wired up a '65 FJ45 (admittedly pretty simple) with an aftermarket harness and fuse block, and it worked great. And, it wasn't the Painless brand, it was a well-made harness that was about $150 and came with temperature-rated wire and all wires were labeled on the wire itself. I had to lengthen the taillight section to reach the rear end of this pickup, but all else was easy.
I have an FJ but it has a B engine. The whole truck is 24V
were all Bs 24v? just curious, dont know that much about them, sorry to hijack
Not sure either. PO changed the engine to a Diesel. I'm pretty sure it had a 12V 2F originally.
There's some crazy wiring going on at the moment. I think the cluster and perhaps other things are 12V, because there's a lead coming from the first battery and there's some fuses on it.
