So we are looking to begin importing the Eaton / Harrop Electric Lockers from Ironman for Land Cruisers but would like a little feedback to gauge interest in the product.
The cost will be $1599 per locker (if we get enough interest) which includes the Locker itself as well as a Wiring Harness and required switches and relays to install the locker. Install into the carrier is the same as any other full case locker.
We should be able to get any lockers in their product line however they are all still in Australia at this point. Ironman has them in stock in Melbourne and ready for their next container if we get enough interest.
Below is an excerpt from Ironman's Product Manager:
The Ironman Diff Locker is manufactured in Australia in conjunction with Eaton Corporation and Harrop Engineering is a new age electromagnetic design which is maintenance free. covers the range of Toyota Landcruiser and Hilux and Nissan Patrols.
Ironman diff lockers are
· . 4 pinion design
· Push button operation ( no air system or plumbing required )
· Maintenance free
· Driver controlled to provide full axle locking
· Assembly kit includes all wiring
· Fully Serviceable
The initial range of Ironman Diff Lockers covers the range of Toyota Landcruiser, Hilux and Nissan Patrol. It has been engineered to capture 100 per cent of available torque sending it equally to both ends of the axle.
When the Locker switch is activated, electric current is supplied to a powerful electromagnet. As the electromagnet is energized, a torque is created on a drag-plate that activates a ramping mechanism. The ramping mechanism, in turn, translates rotational force into the axial motion of a locking mechanism. The locking mechanism engages into slots or tabs on the differential side gear and locks the side gear rotation to the differential housing. The result is on-demand traction and a fully locked differential.
The Ironman Locker is built with precision gears that are designed to mesh perfectly providing strength and durability over a standard gear cut.
Please fell free to ask any questions and we will do our best to answer them or we can pass the questions on as needed.
Thanks,
· . 4 pinion design
· Maintenance free
· Fully Serviceable
Thanks,
