- Year
- 1965
- Vehicle Model
- 40 Series
- Location
- Durango, Colorado 81303 United States
- Color
- Red
This is a truck a customer bought off here this summer and had me do some repairs and install some parts. It’s a 65’ tagged and titled as a 67’. They are looking to sell it and get into a 77’ or newer 40. They are willing to trade or sell outright. Everything works and runs good for its age. Very solid original patina truck. Was an old hunting truck so a little beat up body wise. Lots of work done by previous owner and myself that I can run through if someone is interested. It’s still located at my shop in Durango, CO $16,500obo or trade for late 40.
Work completed by myself or previous owner with very few miles.
Head replaced with rebuilt/machined unit using OEM gaskets
SD-40 Carb rebuild
Steering box reseal
Centering arm rebuild
Gas tank and radiator boiled and cleaned
All coolant lines replaced
Water pump rebuilt
Fuel pump and fuel filter restored/rebuilt
New battery
Fog lights installed with factory switch and factory style harness
Factory wheels powder coated with new tires and new repop factory hub caps
All steering linkage replaced with new OEM style from Cruiser Outfitters
New wiper arms and blades in factory style
New Factory Soft Top
New plugs, wires, cap, points, rotor
Located correct color FST doors and installed
Dealer installed heater refurbished to functional
Warn 9,000 lb winch added with synthetic line
Steering column shifter rebuilt
New OEM turn signals
New OEM tail lights
New OEM coolant sensor
New Speedo Cable
New factory style seatbelts
All leaf spring/suspension bushings replaced
All fluids are new with all new OEM fill and drain plugs
New Jerry can with ConFerr mount for spare tire
Front rubber brake lines replaced
New Brake and Clutch Master
New Clutch Slave
New OEM side mirror arm
Factory TNK wiper motors repaired and functioning
New thermostat
Motor resealed when head was installed by previous owner.
I have videos of it running and driving in high range around 50mph and In low range.
I am sure I am missing a few things
$16,500 obo or trade for 77’ plus 40.
SD-40 Carb rebuild
Steering box reseal
Water pump rebuilt
New battery
New OEM tail lights
New Speedo Cable
New Clutch Slave
New thermostat
