Got the tub sprayed today and thought I would list some directions and tips
1. Use good quality masking tape (ran out and had to use other then 3M, not good)
2. Scrub the body with tsp and rinse.
3. Scuff all body areas to be lined with 100 grit sand paper.
4. Blow off dust or vacuum and scrub again with tsp, rinse.
5. Mask all areas you don't want liner. Cover windshield and dash. Place tape over all exterior holes on finished surfaces. Be Sure To Get Tape Pressed Down Firmly
6. Prime all bare metal areas. I sprayed entire tub with zero rust
7. Let dry (if using zero rust a few days)
8. Stir up durabak, a small paddle in a drill motor helps. Depending on how coarse of a texture you want, thin accordingly. Use no more then 15% by volume of Xylene
Thick = coarse
Thin = smoother
9. Wipe interior with xylene, (a respirator helps) Do not use any other solvents. Plug all holes, use bolts or small balls of tape.
10. Set air pressure.
Higher pressure = smoother 55-60 psi
Lower pressure = coarser 35 -45 psi
Texture will also depend on gun tip size 3/8 vs 1/4
11. Spray in a small circular motion. Put on 1 even coat. A small brush and cup of durabak for those hard to reach areas. (nook behind front door pillars).
12. Clean gun
13. Let first coat cure till tacky and then recoat.
14. Clean gun
15. Remove masking before durabak completely sets. Have clean rags and xylene on hand to remove any bleed from under tape. Remove all bolts and tape from holes. If planning on re-using bolts place in can of acetone and soak for 40 min.
Tips:
Remember humidity and temp affect curing rate. Hotter, more humidity = faster cure.
When setting air pressure do a test panel to determine texture.
1 gallon of Durabak will cover the floor/bed of a FJ40 with the recommended 2 coats. I think a 3rd coat would be better.
Use gloves, a respirator (if not outside), keep away from flame. Remove masking promptly. Do not over thin ( rubber separates from poly).
Put down drop cloths to cover anything you don't want speckled with liner
Supplies:
Masking tape and paper, 1 gal xylene, 100 grit sandpaper, 1 gal durabak, astro pneumatic ucg-100
Thick = coarse
Thin = smoother
12. Clean gun
14. Clean gun
Tips:
Supplies:
