Dumb Overdrive question..
Seattle, Washington
Ready for your daily dose of dumb questions?!
So here's a dumb question regarding the overdrive. I'm assuming the overdrive is a small version of the main auto transmission. Should I be changing the oil in it? Is that even possible?
Thanks in advance
Nope, the overdrive is not a separate entity. It is a gear inside the main transmission. So just change the main transmission fluid and you will be fine.
Thanks in advance
Yes that system is separate, only works on 2wd cars and trucks and has it's own oil supply.
OK I must be thinking gearvendors overdrive. But even then don't know if that system is seperate.
Not a dumb question when you are just making sure you have all your preventative maintenance done.
Thanks in advance
I read through this thread and I hope you're not mistaking the transfer case for an overdrive unit "a small version of the main auto transmission". The transfer case (some call it the center diff) does have it's own oil supply and does need changing periodically. It hangs off the end of the transmission and both drive shafts are powered through this unit on the stock 80 series.
X2 and just so we all don't assume you're question has been answered completely.
