Yes, the grey 20111 model number is apparently still produced. The tan 90112 shows discontinued.Did you find one in another color?
I did that setup a couple years ago. My pod was a freebie from someone else's project that changed plans, so he gave me the pod. It goes all the way up to the top of the A pillar. I could of shortened it, but I liked the way it is secured by the grab handle. I run an EGT and a combo vacuum/boost gauge. Vac tells you how hard your pushing the motor when your NOT in boost.
feel free to expand on where tubing goes and where you got it, this is old link is vague on sizes and locations./I'm glad someone bumped this, thread I plan on doing my pod mounting today
Im having no luck finding where it plugs into intake.just run a vacuum line from the gauge to the intake manifold. I bought a 1/8" BSPT - 4mm hose barb that I plan to replace the 1/8" BSPT plug used to eliminate the brake boost nipple on the back side of the intake.
I T red into to front on the intake because the Allen plug in the rear was stuck. I did it before I rerouted my PVC line due to the super charger.Im having no luck finding where it plugs into intake.
and you went fitting hose to guage thats it for boost?
but this fitting does more than i need correct??
Looks like either the 4x4 concepts dual from AUS or an old acura integra pod.Where did you get that pod?
4x4 concepts makes a LHD 2 and 3 gauge pod. Reviews are not the best on here from the few i've seen that had them but it's one of the best options out there. Definitely weird an Australian company makes a LHD pod.I have an Integra pod and it is not like that one. Does the Australian company build LHD pods? That seems a bit odd.
The issue i have with pulling the trigger is that they're like 150+ bucks, and you lose the grab handle.
