I thought I had this one licked! Now I've got a problem and I need some help from you guys with electrical knowlege/experience.
I installed a dual battery set up in my truck about 1 month ago. It has been working flawlessly. Since I was running off my #1 battery and not using the #2(aux battery) I decided to check the voltage cause it was essentially just getting charged all the time. I check the voltage and its 11.89v main battery is the same. WTF! Truck is starting right up no problem so I do some investigating. I find that the 25amp fuse I have on my charge wires are both blown (isolator to batteries) not sure what size to use cause my diagram called for a 10a circuit breaker that sounded like a clock--tick-tock on and off. So I don't know how long I've been driving around with these guys blown. So I throw in a 30amp auto reset fuse and take it out for a charging run just figuring the batteries are low cause they have not gotten any juice.
After 15 minutes of driving I pull over to a well lit station and pull out the voltmeter with the engine running my batteries are now at 11.6 and 11.89 volts. I check alternator output and its 0.5v rev the engine and it reaches 1.8v. So whats the story?
When I originally tested the system my batteries were new with voltage >12.2v at rest. Up to 14.5 running. I had 15.2v from the alternator to isolator and 0.7v drop there so I had 14.5 at the batteries. So everything checked out, no fuses blowing.
Here is picture to help with the problem. My dual battery setup is running off a standard 3-wire AC delco alternator, nothing fancy just what was on the sbc when I got it. Blue box top left is the isolator. Central wire is feed from the alternator, right and left to to batteries. The right (as you look at it) goes to batter #2 (aux) or top one in the picture. Left red wire goes to the starter battery (#1). They both have a ATO/ATC fuse holder in line with a 25.....now 30 amp fuse (why? I don't know but my schematics called for it). Marine switch (red) control power to the starter (right now my output is to the starter...later it will be switched to a winch--when I get one). YELLOW wire on bottom batter (#1) is the remote sensing lead off the alternator (this is how I got around the voltage drop at the isolator by reading at the battery instead.). Hope that helps.
So here are my questions:
1) Looks like my alternator is dead putting out just a couple of volts????
2) Did running the alternator into a dead end (charge wires to batteries from isolator blown) kill my alternator?
3) What size fuse do I need to run between the isolator and batteries? Do I need a fuse at all? Is a fusible link a better option in this case?
4) Where do I get a cheap 50-90 amp alternator? (isolator is rated for 95amps)
5) Does it hurt to be charging a battery off the alternator when its essentially just sitting there? I don't have any accessories hooked up to my aux battery yet.
6) Could the sensing wire location have anything to do with this problem?
7) Will someone come and rewire my entire truck?? I'll buy the beer, cocaine, heroine..whatever you want!!!!
You help is greatly appreciated. I can't figure how I am going to get away without getting a new alt but if I caused this I certainly don't want to do it again by not fixing the problem. Perhaps this was just a tired alternator and gave out but the timing is suspicious given the recent changes I've made.
