DS Wing Mirror Replacement Suggestions....
Los Angeles
While driving on the highway recently, I got hit by a piece of debris kicked up by a car ahead of me. It smashed up the driver side corner-light and hit the wing mirror pretty hard. Fortunately my window was rolled up and it ricocheted from the glass, otherwise I would have probably been hit by it as well. The sound of the impact on the mirror housing and window glass was explosive. It pissed me off to see the damage once I pulled over to inspect. The actual mirror glass is fine and the electronics work, but the housing sustained nasty damage. Anyway, the corner-light was $50 from Toyota and I replaced it but the mirror is way over $300. However, I want to replace the mirror and was wondering if anyone has installed an aftermarket one. Toyota dealership tells me the aftermarkets don't have distortion free glass and best to go with OEM. The price difference is quite a lot though. If the design of the aftermarket ones are ditto as an OEM, could I get an aftermarket one and fit the original glass on it, since the mirror itself was unscathed? Any thoughts, advise on this will be highly appreciated so I can save a few bucks and put it towards much needed PM expenses.
I have no experience with non-OEM mirrors but I would bet that the knock off mirror housing likely used the same size glass. If you want to continue to use the OEM mirror glass then you can remove it by warming up the glass surround using a heat gun. Just needs to be pliable enough to get something between the glass and the plastic. I used wooden tongue depressors. I just worked it a little at time moving around the edge. There is a foam double adhesive tape holding the glass on. Just keep working the wedge of your choice carefully and it will pop off. I do not recommend using anything metal as your wedge.
@arcteryx is the guy for used parts he can probably hook you up.
Thank you both for your suggestions. I have sent a PM to arcteryx to see if he might have one on hand for sale. If not, I will try the method nlxtacy suggests.
I bought those Amazon units for $60 each. But a year later they have started to shake but no more than the OEM did. For the price I would buy them again.
If you are just looking for the housing, I have that. Per our conversation, I thought you needed the entire mirror, which I don't have currently except new. If you innards are good, a housing should do. PM me if I can help.
ps- that does really suck, whatever was kicked up hit hard!
