Wow, you're smart....
Just experienced. You learn a few tricks after 30+ years as a trouble-shooter.
Sometimes swapping things around is your only tool.
Keep us posted.
Did you check the plug in the DS kick plate in the A-pillar? Mine was doing something similar and I discovered that it was pulling apart. I pulled it out, unplugged it, plugged it back in, put a zip-tie around it, and put it back in. MOST of my window problems went away (not all).
So, I completed these steps this evening. With the PS switch operating the DS window, I get the same issue. When done with that test, I replaced the switch with a new master switch from SwitchDoctor. I get the same result.Since all the other windows are OK, I would say the problem is most likely in the DS motor/wiring.
I would confirm this by swapping the DS motor wires with the wires for the PS motor. You can do this at the master switch, pull the #6 & #13 wires and swap them with the #12 & #5 wires respectively. You'll then use the PS master switch to operate the DS window.
If the intermittent problem stays on the DS, you'll confirm it's the motor/wiring. If the problem moves to the PS, it's a control (master switch) problem.
The return or ground path is the same for the left front window as it is the right front window. If one works and the other doesn't (from this switch), the circuit I traced in orange is probably okay. However, it appears to go through a resistor to sense the current when the switch is in the auto-down position. I just don't see how that resistor could be the problem if you swapped switch modules.
The yellow path is out and back for the motor. The motor can be made to turn either direction depending if the up or down switch is flipped (you can't do both mechanically). If you're losing up and down when it fails, it probably isn't in the switches as the contacts would be different depending on direction.
That leaves you the motor and the wiring out and back, I traced it in yellow. Or the motor.
You're not blowing fuses or hearing loud popping noises from the switch, so it probably isn't shorting out (across the motor somehow). That means the motor circuit is going open.
Solder a piece of speaker wire across the motor + to - terminals. Then solder a 12V lamp on the other end of the speaker wire. Put it all back together enough to test it, and watch the lamp. If it goes out, you have something opening up. If it lights up and the motor doesn't move, bad motor. You can also do this with a meter.
How does that motor connector up behind the speaker look? Fully seated? Not melted? You may be able to measure voltage there with a set of meter leads. You will see + or - 12 Volts based on direction. Measure motor + to -, don't use chassis or ground as a reference or you may get confused. Good luck.
Uhm, no, I don't dareDo you dare swap the switch back to see if it was the connector or the switch?
