Drum Brake Crazy!!
Ref: 1971 FJ40 with drum brakes.
Can someone offer a diagnosis of this problem?
There has to be a better way. Every time I come off the trail my brakes are almost all gone. I have to pump my brakes 2-3 times to come to a stop. Routinely, I have to re-adjust my brakes because they are not only loose, but will always pull to the right.
I don't know if this is related, but I ALWAYS have to re-adjust my steering wheel back to the center again. I do this by setting the wheels straight, take off the steering wheel and put it back on situated correctly.
Help is appreciated!
Check to see if you have a leaking MC or slave cylinder. Or, you may not have the shoes adjusted out far enough yet, and you keep centering them and having to readjust. It should come to an end if that's the only problem.
This should not affect your steering.
If you have to keep fiddling with that, I'd say something between the steering wheel and the steering knuckle is loose, and I wouldn't drive until I figured out what! :eek:
I've never had a problem with my drum brakes?
If you have to pump your brakes...your either losing fluid or have air in the line...Check your master cylinder...wheel cylinders for leaks...
Are your brakes wet when this happens?
What he said plus, removing the wheel and replacing it is not a very good idea. I'd find out what the problem is and cure it quick before driving anywhere. I'd start by pulling all drums and see if a cylinder is leaking, then go to MC and so on.
Steering: Pitman arm loose on steering box? Steering wheel to column splines stripped? Steering box completely worn out?
Brakes: Check for leaks in the master cylinder/booster. Put it on jacks, pull off wheels, pull off drums, clean out mud, check the adjuster limiters are there and functioning, check the adjusters work smoothly, put anti-seize on them, look for any signs of leakage from wheel cylinders, look for grease/oil on shoes. Turn drums to remove that outer ridge that developes.
Fix any of the above that is not correct THEN choose one drum measure the inside diameter of the drum with a micrometer or other tool then adjust the wheel cylinders EVENLY to match what you measured minus about 1/16". Install drum, repeat three more times. Stomp on brakes a few times to center shoes then try turning the drum. if you hear a slight drag on that drum reinstall the wheel. No drag, then contine to adjust each cylinder EVENLY till it drags. Install wheels and go check out your now correctly adjusted brakes.
do a front and rear disc brake swap, period. The stock drum brakes are a PIA and discs are done after you install, no fiddling with, they just work. One of the best mods so far. I am not a purist, but any cruiser I own or do own gets the drums ripped off first, a #1. Bring on the hazing, :)
Noah
If you have to pump them to get a pedal, then you aren't adjusting them correctly. Tighten them (both shoes, one at a time) until you can't turn the wheel and then back off the adjuster 3-4 clicks. You can still hear the shoes dragging, but this is normal.
If it pulls to the right, there may be some other issue, like dirt/brake fluid/grease on the shoes.
Turn the drag link rod (between the Pitman arm and the center arm) to center the steering wheel.
