So I'm planning on dropping my tranny/tcase so I can replace the seal between them and potentially the access gaskets on the tcase if needed.
It was my understanding that to do this I needed to remove the tranny hump cover inside the truck first. So tonight I set about removing the seats...
After getting the pass seat out I noticed that
1) there are bolts for the tranny hump cover somewhat under the gas tank.
2) there are bolts for the tranny hump cover behind the heater.
Does this mean
1) I need to remove the gas tank to remove the hump cover?!?!?
2) I need to remove the heater under the dash?
Or, wil the cover lift off and out of the way anyway? I know I can get to the bolts, that's not the issue. The issue is whether the cover will lift off...
Ugh.
If I keep taking parts off this thing, I might as well just do a frame-off on it.
Does this mean
Ugh.
and NOT replace the rear-seal or re-do the clutch. I will just drop the tcase and replace the seal there.
