This is the setup i used on my HDJ81 for wiring my daytime running lights. I can thank my dad for thinking this idea up. He also used this for wiring his hzj73 except he used his auxiliary lights as DRLS.
So here we go.
What you will need give or take.
-some cheap wire
-wire stripper/cutter/crimper
-a few connectors (4 that you can put a bolt through, 6 that you can slip over a prong)
1) I changed my two corner lamp bulbs to an amber bulbs. They are dual filiment amber bulbs and they cost me about $3 for the pair from my local Napa. Change em if you have clear corner lights.
2) Thats the power box which i used to harness the power from.
3) This is the inside of the box. There is a 20 amp fuse and 2 ten amp fuses. The 20 amp is live all the time, while the 2 ten amps are live only when you turn the key. So we used the one ten amp. as seen below.
4) the back of the corner lamp socket has three prongs. One of the prongs is a ground (Dark wire). You are going to need to ground that prong (dark wire). The other two you will need to run a wire from the power box to one of the prongs. In one of the connectors you are going to need to put two wires together and run a short length of wire to the other prong. (Purple wires)
For people who are like wtf is he talking about i have made this one diagram to hopefully make things a bit more clear.
5) Repeat for the opposite side corner light.
6) Marvel in at your awesome DRLS. (sorry i will take a shot later when its dark out)
Hopefully that made sense. If not please feel free to criticize
So here we go.
-some cheap wire
