drivlines
Boise ID
Im about ready to lift my fj40 4 to 4 1/2 inches and I was wondering if Im going to have to mess around with the drivelines. It is all stock Stock F with three speed. If so were are some places that I can get some good ones that are affordable
probably, any driveshaft shop should be able to re-tube them. don't forget the brakelines
Unless you have a rediculous amount of droop (revolver shackles etc), you should not need different length shafts. Ujoints that are borderline now may fail after the lift, as more stress is added.
You can install ujoints yourself with a vise, hammer, and some sockets. Or any driveshaft shop could do it.
Find some old retired guy with a lathe and have him re-tube your stock shafts - that's what I did and having a machinist on your side is a great start to buidling on your rig.
Also check FAQ/tech here for all the brake hose numbers.
What type of lift?
Some people say you do; some people say you don't. I just put on HFS 4" springs and was not comfortable with the slip-joint engagement that I had left. I'm having the shafts re-tubbed. Not much; about 1-1/2". Another local guy had the rear shaft separate following his HFS installation and it resulted in a lot of additional damage.
Look at the shafts carefully following the lift and act accordingly.
HTH.
Todd Bull.
You can pay now, or you can pay later. Unless your spline engagement is optimal, you are going to increase the lateral stress and the psi on the remaining spline engagement if you don't retube. Then you won't have anything worth retubing down the road. My .02.
