Driving With O2 Unplugged
North Front Range, CO
As I am 1000+ mi before I go home, is it ok to drive with one O2 sensor unplugged?
Should I unplug both or just the one that is having problems?
Is it ok to leave it this way till I get home or will it cause problems with the motor?
You will definitly pull a code or two and set the engine light on. Thinking it would be fine other than that. Best gauge is to see how it runs and if it begins to run rough before you leave where ever you are, then re-group.
I am 75% sure it should be be OK
After thinking about it, if one is causing a problem the most it could do is pull a code, why unplug it?
I would leave the one that is working plugged in
x2
I'd just leave it in.
X3.
My '94 has an intermittent O2 CEL that comes and goes. I've got an O2 sensor that is right on the borderline when you ohm it out with a meter. If it has any effect on your rig it would probably be just gets worse gas mileage. I also vote to leave it plugged in and replace sensors after you get home at your convenience.
I drove from Phoenix to Grand Junction with the one O2 unplugged. My performance seams better and my gas mileage is up. I am thinking of unplugging the other and maybe disconnect the EGR and see what it does to the gas mileage.
Drove all day with the bad one unplugged and it ran like a top. Drove in the city traffic and in the mountains. I would never know there was a problem other than the CEL is on.
That's been my experience with my '94
Kurt,
When you say "my gas mileage is up.", by how much? Give us a from and to. My reading threads on this forum has led me to believe that, where the O2 sensors are involved, the best gas mileage is experienced with good and working ones. The best mileage that I was getting before my intermittent O2 CELs was 17 to 18 MPG driving DD about 70 miles per day mostly 2 lane highway, which here in Oregon is 55 to 65 MPH. Now, used occasionally for short trips usually 400 miles round trip, I'm having trouble getting above 15 MPG. But, I've left the sensors connected and the CEL will go out on its own, same as it comes on. And I'm hauling more weight than when I was using as DD.
I have not drove the 80 much this year and mileage has been 11 mpg. When the O2 failed I got 13 mpg and when I unplugged it I am getting 13 and 14 mpg.
One thing different is the gas was 87 octane in AZ vs 85 octane CO. It was about 30 deg warmer in AZ vs CO.
I need to add that I put the timing back to 3 deg advance and put Lucus oil treatment in the motor too.
I will drive to Denver this week. I will see how it pulls Vail Pass.
Kurt, if your here wednesday evening. Stop by for the Rising Sun club meeting and beers afterwards. We have some experts who you could ping for advice . . . for a beer :D No I am not one of them
Thanks Romer for the good time at the meeting and nice to meet you.
I plugged in the bad O2 today and drove home to Grand Junction. The CEL light turned off and did not return and it idled like normal. Must of been a leaf blocking the sensor or something :D
Here is a related situation, just last night while driving back home into the mountains from calgary and while passing a truck on the highway one of the 02 sensors popped out of the bung! quite noisy! I stopped and both nuts had backed off and are missing so i zipp tied it back in which did not last long so with no other options i drove home 200 km in the dark with no issues other than the noise.
So the question, does anyone knw the size, thread pitch and thread count f the two nuts i need to replace?
Cheers and thanks Peter
