Drivetrain Squeal
Murphy, TX
Every time I left left off the accelerator pedal, I hear a noticeable squeal. It happens when I go to shift gears and also when I coast in 3rd or 4th. I'm thinking it is coming from the transmission because it goes away when I press the clutch pedal. Sounds like metal on metal and something isn't fully engaging or disengaging.
Any ideas on what this could be and how to fix it?
I don't see how it could be the T/O bearing; this bearing only spins when your foot is on the clutch. Any noise from the T/O would be affected by clutch position and engine speed ONLY.
You said the noise is different depending on what gear you're in (audible when coasting in 3rd or 4th). That says the noise is inside or after the transmission (output shaft, tcase, driveshafts, differentials) and cannot be before it (engine/clutch/input shaft).
However, a noise that disappears when pressing the clutch could indeed be the T/O... it seems like some of the information you've given is inconsistent, perhaps the TO bearing is dragging and you just can't hear the noise sometimes. You can exonerate the T/O bearing fully by checking your clutch slave end play (or clutch pedal freeplay) per the FSM. This will ensure that the T/O is not dragging on the pressure plate, which is the only way a T/O bearing could make noise when you're not stepping on the clutch.
X2. I think your release bearing needs to find the trash can.
Rick
Basically I agree to what you're saying, Amaurer.
If just lifting the throttle alters the kind of sound, it has to be either in the gearbox or transfer. Some more info is needed.
Does moving (gently pressing against) the gearlever alter the sound as well?
One more remark. Because the ODO-meter doesn't work, when was the last time there was an oilchange in the drive train?
One more remark. Because the ODO-meter doesn't work, when was the last time there was an oil change in the drive train?
The squeal occurs when I let off the pedal. When I'm driving, say in 4th gear, and let off, I hear a high pitched squeal. Also hear it when I upshift from 2-3 and 3-4. It goes away when I press the clutch or when I get below a certain rpm.
I changed the engine oil, which was very black by the way, a week ago. This weekend's project is to change the trans and t-case oil to see if that helps any. They are both leaking and the oil is very black as well.
Did you check your old oil for something weird .. like a heavy sediment ?
Did you check for play in your rear DS and pinion joke . ?
Yep, thats not a clutch problem, you need to look at tranny or tarnsmission. It sounds like any time there is drag on your input shaft (e.g. from the freewheeling engine) and your gears ride on the coast side, you're getting a squeal.
My guess is on transmission rather than transfer, given the way its gear-sensitive.
Did you really say your tranny/transfer oil is black? That sounds no-good....
I did check the oil for sediment and didn't find anything to be concerned about. As for the prop/yoke, I didn't even think about checking it. Thanks for the tip!
I need to correct and clarify that statement. The trans/t-case oil is dark, but not quite black and is still somewhat transparent. It looks as though it hasn't been changed in ages, which is definitely not a good thing. This is coming from the drain plugs and the parking brake on the t-case. After further inspection, the oil that was black was dripping off the bell housing from the hole on the underside of the transmission.
I should know more tomorrow as I spend some time changing fluids and checking things over.
Black oil is engine oil because it has carbon in it. Gear oil only goes black/dark when it leaks and mixes with black oil.
The leaking could be a rear main seal. It sometimes gets on the clutch allowing a little slippage.
Generally clutches squeal,gearboxes whine. Big difference in $$$ too
when you drained the tranny, how much oil came out?
when you drained the t/case how much oil came out?
i am beginning to suspect the dreaded imput oil seal failure and the sqeal could be coming from either...
i am beginning to suspect the dreaded input oil seal failure and the sqeal could be coming from either...
Finally drained the fluids in the tranny and t-case. The tranny had a lot more than the specified 3.3 quarts and the t-case had maybe a quart in it. This tells me the seal has failed and is pumping fluid into the transmission.
yep, sounds about right...
teh worse i have seen yet was the tranny overflowing out the shifter tower...
the customer just kept filling the t/case every month or so but never bothered to check the tranny...one day he comes over and there is fluid pouring down the side of the tranny...
this is after he went to Toyota for an inspection, they told him he needed a new tranny AND t/case with an estimate of $7500...
fixed with a new seal...
