OK, lots of doubters in this thread. I can report it works quite dandy
3" body lift, 2.8" engine lift, 2" trans mount lift. 365/75R16 tires, stock wheels. Some trimming of the front inner wheel wells, and of the flares front and rear. It works.
Why I choose to go this way:
- Its cheap.
- No messing with suspension geometry. I've read enough of this forum to realize the FJ80 suspension does not take to a lot of lift. Quirky handling, in some cases with catastrophic results.
- Gain clearance to flip the exhaust above the frame, which should allow installation of sliders that do not have goofy cat protection systems. This is on the to do list.
Having done the mods, there are a couple things that I did not think of, or had read about that need to be addressed:
- Steering, namely the steering shaft that goes through the firewall. When you lift the body, the angle of this shaft increases, and interferes with the firewall. I had to slot the opening, and make a spacer between the rag joint to get the shaft to turn without rubbing and binding.
- Power steering return hose. It is too short for a 3" lift, needs to be replaced. Mine was leaking, and it is just a straight length of tubing.
- Before I lifted the drivetrain, the engine to heater valve was too short, had to be replaced with a universal formed el. Once I lifted the drivetrain, I had to shorten the new hose back to stock length.
Lifting the drivetrain along with a body lift addresses a lot of the issues with a bodylift alone. You do not have to adjust radiator mounts, air intake hoses, various wires, etc.
To the sharp eyed reader, you will note the engine was lifted higher than the trans. This was an accident. I used 2" x 4" tubing as spacers for the mounts. The trans mount is flat, and as a result it was lifted 2". The motor mounts are at a 45* angle. The 2" blocks lift the engine 2.8" as a result (2/sin(45)=2.8). This actually worked out well, as it allowed me to use the stock exhaust under the frame without any issues. I also have no drivetrain vibrations.
I'm happy with the results thus far.
