drivetrain dilemma
Greenfield, MA
Website
thecarpentryway.blogspot.com
I have a 2H diesel in my 47 series with an H41 transmission. I plan to use the vehicle as a work truck, and as such it will spend 90% of its time on the road. I need to do something about the overly low gearing. The rear end has 4.11 (K082) gears. I'm planning on getting 31" or 33" tires.
Option 1: get an H55F. I can find one locally for about $14-1500, and it bolts right up. Problems: parking brake wil need some $$ thrown at it, and the top loader from a 60 series vehicle does not exit through the transmission cover plate in the same place, so i will need to cut another hole and patch the existing one, and re-bend the shift lever. This affects the carpet and floor mat situation. The correct top loader cover plate for the 40 series 5-speed is as rare as hen's teeth, so I'm not anticipating finding one anytime soon. Still, the 5-speed would be nice to have.
Option 2: replace the H41 with an H42, and swap out the rear end gears for the 3.70 (K052) set up. I am not sure exactly what the net result will be for freeway driving speeds. I need to keep the engine rpm's down -that's really important with the diesel. The H42 will be half the price of the H55F, and the transfer parking brake will bolt on. The stock trans cover plate will work just fine, and selling the H41 should be easy as lots of people want them.
Option 3: ?? I'm looking for other ideas.
What's the best course of action?
- Chris
put 33's on and see where you end up, swapping out your gears for 3.7's won't give you that much of a diffenece in fuel mileage. Others have posted about this and it doesn't seem worth the cost of the gears vs. fuel savings. It is only like 1 mpg difference from what I have read.
Tire size can make a huge difference in engine rpm's.
what size tires are you running now?
Seems like an awful lot of money and work to invest to get better gas mileage, you will be hard pressed to make up the difference in fuel savings.
my .02
I'm not running any tires right now - the truck is completely apart and I'm just starting to put it back together. After I picked it up, i drove it around the block and then started the strip down. I could tell, however, from just that short drive, that the gearing was WAY low.
This is the easiest time to deal with drivetrain changes, as the cab is completely removed.
I'm less concerned with fuel economy than I am with being able to run all day at 60mph/100kmh with the engine turning at, say, 2500 rpms.
I'm surprised that the rear axle gear change doesn't make much difference to fuel economy though...
Okay, here's an option 3:
find a 5-speed out of a BJ42, then rebuild that transmission with the correct input shaft for the 2H. This would solve the top loader plate issue. This transmission may be hard to find however.
One of the things that is hard to figure out with all the factors involved, is how the engine will perform during everyday driving. It would suck if the result of gearing up to get better highway performance was that the engine didn't have adequate power reserve and I had to downshift with every little hill that came along (reminds me of a Volkswagen van I used to own).
What are you hoping to gain by going from a h41 to h42? Any 4 speed you put in will still be a 1:1 ratio in 4th. If you put on 31" tires, you will have no trouble running at 60mph even with the 4.11 gears. 33s will bring the rpms down even more.
Are you sure you didn't have the transfer case in low range? Did you try it out on the highway? I have 4.11 gears with 31" tires. At 60mph, I'm running at about 2800 rpms on my F engine.
Just trying to keep you from spending money where it is not needed. If you want a 5 speed and are willing to spend the $$$, then go for it. I would love a 5 speed in mine, but it certainly isn't a priority.
Good luck!
Edit, I just noticed it was a diesel. Not sure if anything I wrote really applies other than 4th being a 1:1 gear ratio in any four speed.
Hey, great response. In fact, I am NOT sure whether the truck was in 4wd low or high when I test drove it, as there were a lot of things I was trying to pay attention to. :doh:
Good point about the 4th gear ratio being the same between the H41 and 42 - I knew mine was low-geared in comparison, but I hadn't taken a look to compare gear ratios. The fact that your truck cruises at 60 mph in 4th at @2800 rpm makes me think that it might be wisest to try changing tires first, and then, if that doesn't net the differences I need, then changing diff gears to 3.70's.
Wow - that would save me a pile of money (which I could spend on other cruiser parts of course).
Good luck!
One question: why do YOU want to go to a 5-speed, given the performance you mentioned your truck already has?
H41 and H42 have the same top gear... 1:1
Swap third members with someone who has a late model FJ40 or FJ60. I bet you'll be able to get two entire third members for next to nothing through a swap.
Run 32 or 33" tires.
3.70 gears and 33" tires puts you at a very reasonable 2500 rpm at 65 mph.
Some math may help
Here's the formula for figuring speed based on gearing and tire size:
MPH=(((RPM/Trans ratio/Xfer ratio/Diff ratio)*Tire circumference)/5280*12)*60
Assuming 1:1 trans ratio:
31" tires & 4.11 diffs @2500 RPM gets you 56 MPH
33" tires & 4.11 diffs @2500 RPM gets you 60 MPH
3.73 diffs get you 62 and 66 MPH respectively
Anyway ... you get the idea. No need to guess about the effect of different tire sizes & gear ratios. HTH.
Alfred
Excuse my ignorance, but what do you mean by "third member" - are you talking about the differential?
Alfred
That's some great info - exactly what i was looking for! It is sounding like the tire change will make a lot of difference. Rubber gearing, I guess.
Bigger tires, then if that doesn't cut it 3.70's
Why not have the gears available to drop your RPMs a little when you are cruising at a higher speed? Overdrive would certainly be nice, but as I said before, it is not high on my priority list. I have plenty of other things that I can buy for the price of a 5 speed. JMO. If money (and time) was no object, I'd certainly have a 5 speed in there already, along with a host of other snazzy upgrades.
Good luck! :cheers:
I am talking about the differential.
The "third member" is the removable part of the axle housing that houses the differential.
Not all axles have this feature, it can be very convenient, ie in your case you can just swap the entire third member with someone instead of having to remove and then set up their gears in your axle like with most Dana axles.
Thanks for clarifying that. I'm a bit new to this, so i don't know all the lingo yet.
If you are at all contemplating the 5 speed, check out the Ranger torque splitter. Although most use it as a lower range unit it can be set up as an overdrive. Much stronger than the after-thought factory 5 speed.
