Well, i started looking into the problem today.
Symptoms: start the truck up, everything sounds normal till I put it in drive or reverse. It sounds like two gears are grinding up front, perhaps like one of the birfs let go. Seemed to be louder on the right side.
In gear it would not move, until I put it back in park and pushed the cdl switch, then noise GONE! So then I cautiously moved it under its own power to turn it around so I could work on it. As I turned the wheels while moving forward, it made an ugly clunk-bang sound and the truck kind of lurched. Enough of that! Very gentle turning of the wheels and I managed to get it turned around and into my driveway.
By the way it sounded, I was almost sure it was in the area of the right birf joint. WAAAAAAY to loud a noise to be a stripped drive flange. It seemed like there was an awful lot of slack when I turned the right front wheel by hand back and forth before there was any movement on the driveshaft yoke.
I pulled both axles this afternoon and the birfs look and feel OK. I'm thinking something let go in the front differential. I drained the fluid, and it was real black with a lot metal fuzz on the mag drain plug. I fished around up through the drain hole with a magnet and didn't get anything.
To pull the differential gears, do i have to remove the tie rod, or is it possible to work it out.
If the diff is hosed, what are my options? is rebuilding it cost prohibitive? I am hoping that it may only be a sheared pin, and not the drive pinion or ring gears.
From those who know, what is the difficulty level in rebuilding and setting up the differential correctly? I am sure I have all the necessary tools, but it has been years since I've set up a diff. Just follow the repair manual? I do have a toyota service manual.
Another question, is it possible that the transfer case could have a problem and be making the sound seem like it is from the front end? It sure sounds loudest at the right front and with the diff located more to the right side, ?????????
Thanks, Dennis
