Driveshaft spline engagement
Phoenix, AZ
Relating to another post
Thread 'Rear End noise' Rear End noise - https://forum.ih8mud.com/threads/rear-end-noise.1376160/
I just discovered the engagement of my rear drive shaft is not good. These were modified years ago by a driveline shop, obviously not right.
I'm wondering how much of the second set of splines need to be engaged in the tail piece? Or more precisely how much room do I need to leave to allow some movement due to Spring compression?
1962 FJ40
Robert
If it’s a 62, then that shaft center section is from another car manufacture… early splines were quite coarse….someone at some time replaced that driveshaft.
Not so sure about that.
You may be thinking about front axle splines.
