driveshaft flange yoke
Lancaster, CA
Hi everyone,
Does anyone know a part number or where I could get a driveshaft flange yoke 68.5mm x 60mm pattern with 11mm stud for the driveshaft on the truck I'm building.
thanx
Craig
It might depend on what your trying to attach it to, might help to know what it came off of. For easy stuff I'd probably call Cruiser Outfitters, for hard stuff I might call @orangefj45 or @OGBeno or @cruiserdan
Part number for the yoke for the FJ40 with four speed is 37315-36010. Changed 8/84 but no 84 were imported to the US by Toyota. If late import or not stock that should be the part number. The pinion yoke change 1/78 because the pinion changed from coarse to fine Splines.
I actually ordered one of those, but it's not matching up with my existing flange yoke. That one is 68x60 and I need 68.5 x 60. I drilled out the holes a little bit, but the center bore (not sure what that's called) is to big and won't lay flush with the output flange. The driveshaft I have is for a 67 FJ45, but this truck had a 350 swap in it with an older style transfer case. I've put in a new drivetrain with a split case. I was hoping the 37315-36010 would work, but no luck with that.
