Driver's window only goes down: Solved
My driver's window only goes down (not up). I pulled the switch and cleaned it. Nothing. I removed the motor, disassembled it, cleaned and greased it. I also greased all the tracks (including the rubber window tracks). It goes up and down nicely if I jump power from the battery to the motor. If I try jumping the leads in the "up" part of the switch I just get sparks (so it's not carbon on the contacts). So either the master switch is bad or the motor is drawing too much current on "up" rotation. What I don't have is an amp meter to check the draw per the factory manual. I think I need to go and buy one. Anything I might be missing? Has anyone seen this?
Thanks....John
Thanks....John
