Driver's drop transfer case
Why keep the H42 if you are looking for gearing and would be willing to drop the cash on a Klune....
Install a 465 and a LHD Atlas...
:beer:
I'd like to be able to drive it on the road nicely.
Lots of hills in these here parts.
An atlas might be a future idea, but I can get 231's cheap from jeep people day in and day out. If it would last long enough to get an atlas (and I don't see why it wouldn't), then that seems like a good way to go.
Everyone says it's garbage, but I've never yet seen one fail. I can't say that about a 'crusier case.
This would also be for my girlfriend, and the last thing she needs is a transmission without a synchro first that will lug the crap out of the engine on a hill.
*GRIND GRIND*
"What is wrong with this thing? I thought you said you fixed it!?"
That is because any person with a clue that operates a Jeep in conditions other than paved roads, has usually replaced the case with something far better, not only to get rid of a junk chain case, but to gain about 10” of rear drive shaft by getting rid of that big ‘ole POS. ;)
Advent said:
This would also be for my girlfriend, and the last thing she needs is a transmission without a synchro first that will lug the crap out of the engine on a hill. *GRIND GRIND* "What is wrong with this thing? I thought you said you fixed it!?"
Teach her that it is a three speed, and how to operate a truck...not drive, but operate....there is a difference.....or move on. :)
Hey, while you are at it, swap in one of those AX5 trannys...probably could find one with the 241 on it already.....should not have a problem finding one of those....
:beer:
How about a Bronco D20 to SM420? What driver drop front axle you running? Are you using headers w/ the Toy tractor motor? Have plans for a PTO? There will be interference problems there. It's also tight fitting a driveshaft on the driver side w/ the 6 cyl.
Sm465's have a synchro first
My wheelin buddy destroyed a 231 in his Heep Cherokee.
*GRIND GRIND*
Never seen one fail
Always remember that anything can/will fail.
Put enough tire/gear/motor together and you can find out what can/will break.
JR
