Drivers door will not open
Sudbury, Ont. CA
Yes I can unlock the PS and still crawl in...
DS. Key will not unlock, power lock will not unlock.
Opened up the PS to look and it seems like DS is stuck in default.
I would like to take the panel off, but of course this is complicated by the door not opening.
In a dim spot of illumination I drilled into the panel hoping that a srewdriver would be able to manually unlock the door but alas something is preventing this. Can feel and move the latch, but just not enough to have the handle catch.
Currently awaiting some jimmy tools, but your help is appreciated.
You need one of those slim jims locksiths and repo men carry to get the door open. I would call a locksmith and ask.
He is coming!
Thanks
On my '92, the little spring that pulls the latch mechanism up broke off the top hook. I lowered the window pushed apart the top rubber seal and managed to pull the latch open with a coat hanger. I then followed much of what the other people with a similar problem did.
I would like to point out that my latch was different, that no spring got worn through or melted and that all that happened is that the loop on one end of the spring snapped clean off. I re-bent the spring hooked everything up and was done in about an hour. The biggest obstacle was 1. the pouring rain. 2. realizing that my '92 is different from what everyone else was discussing.
Thanks to all.
Funny thing is that I heard a faint noise from the door but cast it aside to road drit.
Yes it was the spring, the slim jim guy was helpful in that he did not want to quit and his plastic wedges were great at removing the door panel, especially the top!
Keep this somewhere but bear in mind that mine is a 93 with over 200,000 miles.
Glad you got it open and thanks for letting us know what was wrong.
Grrrrrr. I had this very problem with a Celica I used to own. Nothing could get the door open and I couldn't afford a locksmith. After about a month of acrobatic entry/exit via the passenger door, the DS just mysteriously opened one day. Once I got into the panel I found the linkage had all but rusted away.
So,
Today I removed the wire and daughter's hair elastics temp fix and installed the spring, the spring fits into one of the door seal holes and bee lines to the defective lock mechanizim. If I wasn't so drunk pictures would be posted.
Anyhow being cheap saves $$$$ the spring costs about three $$$
