Driveline Thunk/Vibration
Cranford, NJ
Hi everyone.
Bit of an update and a request for input. 96 Stock 80 series with 288k on it. I've owned for a year.
I've been chasing some vibrations and noises in the drive train.
Here's what I have done so far:
-Front axle service
-New wheel bearings front and back
-New brakes and rotors all the way around
-New universal joints
-Changed diff fluids
-Changed one rear caliper that was frozen
-New tires (Cooper AT3's) that have been balanced a few times, at different facilities, even road force'd
At this point, I still have a growl at 70-75 mph, more pronounced when off the throttle. I have a rotational vibe that is pretty pronounced between 20 and 40 mph (you can hear a rub on what seems every tire or driveshaft rotation). Seems like there is something somewhere that is binding or grinding. And it seems to my seat and ears from the drivers seat that it is in the rear of the vehicle.
At this point I am thinking front pinion bearing?? A few concerns of mine:
-I don't have experience digging into the third
-I don't have a press
-I don't have the dial indicators to measure runout
-Is there a way to test and see which bearing in the third member it could be without removing the unit? I've already tried to move the driveshaft in all directions, and it seems very solid with no play.
Any videos of doing this? I have searched this site and read through a number of threads regarding driveline vibration, and it seems that there are two trains of thought: tear it down and replace all the gears and bearings, or run it and accept that there are going to be vibrations.
I use this as a daily driver with a 45 mile round trip commute. I can work on it over the weekend, but if I get stuck then I get stuck (not unique, I know).
Just looking for any info you guys can provide.
Thanks
You can always yank the driveshaft and drive it around while the front is out of commission. But, I'd do more work to diagnose what the issue is before you go ripping into a DD.
Have you checked phase of each drive shaft? Maybe during u joint service it was replaced incorrectly. Just a guess but an easy one to verify
Need a little more information. What lift (if any) do you have? Do you have stock driveshafts? Do you have a double cardan driveshaft in the front or rear? Any caster correction? This info might help diagnose the issue.
Driveline "clunk" is a common thing with these trucks. From what I understand one reason can be some "slack" in the viscous coupler being taken up either when coming to a stop or starting from a stop. A vibration/growl in the driveshaft (particularly on decel/coast) is also somewhat common. It can be a ujoint issue but since you've replaced ujoints it probably isn't bad ujoints but could be that the joint angles are bad and causing vibes. If you're lifted, a double cardan driveshaft can help and be the right solution. It can also be slop in the splines of the driveshaft and during coast/decal the splines do not have load applied and can vibrate.
As you mentioned it could also be a pinion bearing, but I would look at driveshafts first.
I'd start by pulling one driveshaft at a time and driving it in 2WD (remember to lock the center diff) and see if the noises/vibrations go away with either driveshaft removed. This will help isolate which is the cause of the noise.
MC, I don't have lockers or the 7 pin/cdl mod. Would this still work in 4H?
Hi J, I did the U-joints, and made sure that the front is out of phase, rear is in phase. I've even rotated the slip yoke 180 degrees on each shaft to see if that helped but no dice.
They say you can put it in 4-Low, which automatically engages the CDL, then pull the fuse for the lock, then move back to 4-High but the CDL won't have power to disengage. I have a 92 so I can't test this.
The CDL must be engaged to be able to drive with a shaft out.
96 stock with no lift, stock driveshafts, unlocked without the 7 pin mod. While there is the clunk that I think most people are attributing to the VC or slip yoke, the noise that has me concerned seems to be rotational, where you hear it on every rotation of the tire or driveline. It is quite pronounced at lower speeds, especially when cold. I originally attributed that to my tires, which have a history of flat spots when parked for a while.
But it seems to be getting worse. I may have multiple issues going on, but the growling noise is pretty pronounced on downhills with no throttle, and at speeds over 70 mph. Combine that with the low speed thump, thump, thump, and you can see my cause for concern.
Ok, sounds good. Since one driveshaft is out, I shouldn't have any concerns about binding when driving on the pavement, correct?
Nope! The front is open just like a 2WD truck would be.
One word of caution. The vehicle drives a lot different when front wheel drive vs all wheel drive. The rear seems very light and floaty. Takes a minute to get used to.
In rear wheel drive it seems more fun to drive. Easier.
Also check that you didn't overfill your driveshaft with grease. That can cause it to vibrate and clunk from my experience. It doesn't allow the slip joint or whatever it is called to give.
I saw you mentioned the driving characteristics on another thread. It's going to be interesting, but I will certainly be cautious- thanks.
In regards to the slip yoke, I manually greased the splines, then assembled, then added about 3-4 pumps of grease. Last week I popped both the front and rear zerks off, and there was no pressure or grease that came out. If I have a little time tomorrow at work, I may pop the rear shaft off, make sure it isn't overfilled/still lubed up well, and see what happens.
Yeah, I dropped the rear driveshaft on my face when I was trying to reinstall it. Couldn't get it compressed and it slipped out of my hands. Broke a tooth!
Took the zero off and compressed it then put the zero back in. No problems.
The front wheel drive just takes some getting used to.
Why have you made sure the front shaft is out of phase?
I just checked mine and it is phased in the standard way and it doesn't make any noise or vibration, I do have a part time system but I engage the 4WD with the hubs unlocked to give it a bit of exercise every now and then.
FSM shows it out of phase, and as verified by that and most of the members on here the phasing should be out of phase up front.
Mine is a 96 which is a full time system: no hubs to lock or unlock, so we are not quite comparing apples to apples.
Maybe a granny smith to a pink lady, mine being the pink lady of course.
It might be worth trying the front shaft in phase seeing as you have tried most other things and out of phase driveshafts can cause a vibration in certain situations.
Edit, my car is a 91 model, which explains the front shaft being in phase. I found a thread in here where Beno shows the updated arrangment.
No worries :). I actually had the front in phase immediately after replacing the U-joints, and corrected it a few days after. It didn't seem to make a difference to be honest.
Do you remember the name of the thread?
