driveline noise under slight acceleration
Erie, Co
I bought a 96 lx450 from a member here that had installed a 4" lift, J springs in front. The truck has always had a very slight driveline noise that would happen rarely with slight acceleration/decel that I attributed to the lift and stock driveshaft being somewhat incompatible.
I recently did the landtank 4" caster correction and purchased a double cardan shaft at the same time since the stock shaft had just recently seized on me.
The truck steers better now with the caster plates on, but putting on the double cardan gives it much more vibration that I never felt before, so I went and had the stock unit balanced and ujoints replaced which solved the majority of the driveline vibes, but now under the slightest acceleration I get a noise from the driveline every time. Let completely off or give it more gas and it goes away, but the slightest acceleration like just cruising brings back the noise.
I'm not sure if it is driveshaft related or perhaps an issue with the axle/tcase flanges but thought maybe you guys had insight before I give up and take it to a shop that probably won't know any better. Not seeing much in search unfortunately.
I've also tried taking the stock driveshaft and putting it in phase which made the vibes worse, so I put it back to 90 out. Also does not do this with the front shaft out. You can barely feel it in the pedal. The noise also becomes amplified when driving in 4wd under the same circumstances.
Have you eliminated the rear shaft as the source of the vibes?
EDIT- never mind, just saw that there's no vibes with front shaft out. Any side-to-side play in the pinion or t-case output?
I assumed being that it only happens when the front driveshaft is in, and goes away when driving with only the rear that it would eliminate the rear, but let me know if that isn't correct for some reason.
I corrected my original post when I re-read your comments about no noise with front shaft out. Any lateral play in the pinion or t-case output?
Shouldn't be any.
Being the configuration is broken back and my floor may be off by a few degrees I'm not sure if I need to be calculating a working angle or something to figure this out exactly. In other words, I think if I compensate 2* for a sloped driveway, I may have 1* up at the tcase flange and 6* up at the axle if it were on level ground, but obviously the overall angles aren't changing so not sure if I need to be taking something else into consideration for that calculation.
Using this thread as reference, it would seem like my tcase working angle is 9*, and my front axle working angle is -3* using my first readings with the driveshaft, if I'm understanding that correctly. Am I just way far out of angle and screwed with the stock or dc shaft?
If you have a 4" lift and caster correction the pinion end should have very little angle, not sure how you would still have a broken back config. The angles are measured relative to the center section of the shaft, not the ground or any other reference. Ideally they should be equal. In the 80, lifted, the angles get tweaked, usually with your lift there would be very little angle at the pinion end, so a single u-joint is used there, more angle at the t-case end so a double u-joint is used there. U-joints at angles need to be in pairs to cancel out vibrations, thus putting two at the angled end.
Agreed, that was my hope when I bought it all. I'm wondering if I have too much caster now or something. My front axle angle is 3* up, and my driveshaft is 6* up, which seems to mean that I've passed where I need to be and even lifting the truck would make it even more out of angle. Guess I'm lost as to how I'm this far out. Axle is 3* lower than it should be to match the driveshaft angle. @landtank Any words of wisdom?
Driveshaft
Front = 3.8 * up
Tcase = 3.1* up. pic looks odd being driveshaft isn't bolted up, but i measured it at the flange without the driveshaft on as well, same reading.
I can't tell for sure from the camera angles, but it looks like you are measuring multiple angles at the same time with your positioning. With an old-fashioned mechanical angle finder you need to have the face of the tool perpendicular to the ground (0*) in one plane, and hold one of the sides against the object you want to measure. Anything other than having the face perpendicular to the ground and you'll get bad readings. I'd assume the digital meter you have can read compound angles, so it may be mixing the object's angle with the off-perpendicular angle and giving you false readings.
But for the sake of the exercise let's assume you're getting good readings. Start with the shaft reading of 6.3*, that's your baseline. The front pinion is at 3.8*, subtract that from the baseline and you get 2.5*, which is the angle of the joint. The t-case flange is at 3.1*, subtracted from the baseline gives you a 3.2 degree angle. Or it may be giving you the baseline plus the angle, which would be more like 9.4*, I can't tell from the pics since you have the tool in differing orientations.
You have a 'set 0' option on that meter, put it on the shaft, set 0, and then measure the flanges using the same orientation of the tool. For example, keep it upright, with 'Accumaster' on top, and measure everything from the same side of the truck. That should give you your actual angles, no math required. You would get better measurements if you took off the driveshaft after measuring it and were flat on the flanges, but you should be able to get a decent measurement with it on. Plus the tool will likely shut down in the time it would take to remove the shaft and you'd lose your '0'.
I find it easier to put a short straight edge across the flange, like a metal ruler, so I'm not fighting the studs and nuts, and measure off of that.
Yeah I was just orienting the angle finder to the flattest surface to get the most accurate reading using the magnet on the side, 90* would be 0* angle on the flanges so an angle of 86.2* up on the front tells me it was at 3.8* up. Anyway, took some at the same orientation and zeroed out to the angle of the driveshaft. Not zeroing out the driveshaft first and the numbers were the same as above.
driveshaft zeroed
front axle compared to driveshaft
tcase compared to driveshaft
@landtank do you know if this would be solved by using your 2.5"caster plates instead of the 4" that I bought since my front pinion is pointed 2* down in relation to the driveshaft? I'd hate to do all that again but can't really drive it as it is I don't think.
edit - read somewhere in one of your threads that caster changes something like 1.74* per inch of lift which I believe you are correcting back to stock with your kit. I'm assuming if I installed the 2.5 inch plates instead of the 4 inch lift plates, the correction is 2.61* less (1.74* X 1.5" difference) which I think would put my pinion and dc driveshaft within .4* of each other, but I'm probably missing something somewhere or perhaps there is another solution by me adjusting the lift some?
Honestly I have no idea what you are doing with the angle finder. You have a 4" lift and installed my plates which should align for a DC shaft.
But when you installed the dc shaft it vibrates. Did you also buy one of my shafts?
And to check alignment of a DC shaft you are only concerned with the operating angle of the front u-joint.
Check here to understand how to do that.
DC-Shaft pinion check
I am using one of your DC shafts. My front pinion operating angle is 2.2* (front pinion pointed up 3.8* driveshaft 6*). My lift is the level stance kit, 3.5" J springs up front, 2.5" heavies in rear, using your 4" lift caster plates.
Are you sure there is no other caster correction method involved, such as offset bushings? Are the bushings in good condition? Have you measured your actual amount of lift? It looks like you have too much caster for a DC driveshaft, but are wayyy out of spec for a normal driveshaft (equal angles at t-case and pinion flanges). If you currently have factory bushings in good condition and don't want to change the lift, I'd look at using caster correction bushings to reduce the caster a little. This would be a lot easier than changing the plates, and you can adjust them with a bit of effort.
Good question, but no other caster methods involved that I know of. I actually got stock lower control arms cause the previous ones had caster bushings in them, these are dead center and firm. Haven't measured actual amount of lift. I'm assuming that would be from center of hub to top of wheel well? Can get those numbers real quick if so.
There are a couple of places to measure from, hopefully Rick can point you in the right direction there. I'd bet he's mentioned a method somewhere on this forum, if you don't want to wait.
I believe I've seen in his other posts about measuring from hub center to top of wheel well but could be wrong. Those numbers are 22.75" for front driver and passenger side, 23" for driver and passenger rear. Pretty dang level. Not sure what the stock measurements are, I'll search and see if I can find that.
