- Joined
- Jul 22, 2012
- Threads
- 641
- Messages
- 17,891
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
If you give a mouse a cookie...
I'm putting a NV4500/203/splitcase combo in my FJ62, behind the 3FE.
The gear train will be long, equivalent in length to if one had the stock a440f automatic and put a 203 kit in.
I'm just eyeballing it right now but I think I'm going to have to go to a DC rear driveshaft because of the angle and shortness.
Here's the problem, I have an FZJ80 rear axle swapped in (non-e-locked) which is more centered (2" more I believe?) then the stock 60 offset. That's not going to work with the DC driveshaft.
So here's what I'm thinking: Since I need to cut the perches anyway, should I get an FJ60 full-floating short-side shaft and narrow my housing to use that? Would that put my diff offset back into the right place?
I'm at pretty much stock suspension height right now (SUA) So I figure I can get away with a standard driveshaft and the offset for tooling around on the road but looking at SOA'ing the rear in the long term so I need to make a plan. Any insight?
