Drill powered grease gun
The comments on it are good. I guess if you have that many fittings to do regularly, it would make sense. For how few and how rarely the cruisers need them, I would probably just stick with a manual one. Particularly for bearing that can get too much grease by accident. (slip joint for example)
I'm usually cursing about my hand pump being too big when on my back under the truck...
This looks great, it may be my next tool purchase.
years ago .. I used to have one of this ones, lucas but the one hand model ( like this one ]
.. excelent grease gun
but now this lever model it's the only one that seems to be at sale ..
I was looking into cordless grease guns too .. found few cheap options around 60 - 80 bucks .. coz I don't want to spend 200 in a good one that I use couple of times a year ..
comments are appreciated ..
the one hand pump one is the best leaves the other hand free to hold the hose on the grease fitting ,or any other hose you might want to hold.
I have never figured out what people have against a manually operated grease gun...
for God's sake people, are you that frickin lazy?
:grinpimp:
60 isnt a bad price but when you concider you can get a one hand gun wih the flex hose and enough greese to do the birfs and driveshafts for the next few years, id go with the hand gun. im happy with my hand gun, and use it ehough and youll have some popeye arms in no time :D
Good observation. But you got the idea. ;)
Not sure what the pictures are pumping into the gas tank, but gasoline is required to be in red containers... maybe it's good for putting some water in your tank?
