- Thread starter
- #21
I'm in the process of building my drawers and wonder if you could ask your mate a question for me.
What did he use to mount the center board (on its side) to the bottom board? Did he pre drill thru the bottom piece and then drive screws in to the center piece from the far side or use finishing nails?
I'd like to know what size nails or screws he used. My concern is getting the best bite into the wood, but not split it since I'd be going into the side of the board. BTW, I'm using 3/4" plywood.
Thanks!!
The centre upright was glued and screwed same as all the parts.
He used a drill bit that drilled a pilot hole a clearance hole and countersinks all at the same time. Particle board screws wer used on all parts. The drawers were nailed together first just to make it easier then screwed together to finish them off. Screws were 50mm long.
