Drawers Build
Brisbane Australia
Todays project
Went over to a mates place today and started the rear storage project that I have been putting off for a couple of years now. My mate used to work as a Cabinet Maker so he has all the good gear and know how.
i went shopping this morning for all the bits. The top and sides are made from 17mm ply and the drawers are 12mm. The drawers run on skateboard bearings. There was a slight miscalculation on the number of bearings needed so there are a few extra hole in the pictures.
still got to make the side pieces but we ran out of time and glue for the carpet.
The washers behind the bearing are rebated into the ply for some extra strenght.
Photos
Morepics
The next few pics show the carpet gettingadded
more pics
but wait there's more
A few more
Last one for now.
Hopefully tomorrow I will get some more done and get a few more pics
I had shoes on I am the one behind the camera
Nice job.
Looks like you have a nice shop in your garage.
skateboard bearings
Nice work! How and why did you decide to use these vs. heavy duty slides?
Nice job.
That's the mate's shed. would be nice to have. Makes it a lot easier to do jobs like this when you have access to the right gear. I'd still be trying to get the first cuts straight.
The mate that did the build for me had made a set for his Hilux dualcab and he had used them. The 32 bearing that i bought cost $94.00 plus $20.00 for the 25mmx25mm tube steel. So cost was a big factor. A set of heavy duty slides would have cost a lot more. Skateboard bearings are easy to get from any bearing shop if any need to be replaced.
looks really good, what do you have for a stop so they dont slide out all the way?
There is a block on the outside of the drawer and one on the centre upright as a stopper.
Way to go, congrats. They're x10 sleeker than mine. But I have no friends, let alone one with a shop...;) How will you mount them? U-bolts? Heavy duty wires?
:cheers:
:cheers:
Haven't worked that one out yet. I am considering useing turnbuckles off the bearing bolts to the seat mounting bolts.
I'm in the process of building my drawers and wonder if you could ask your mate a question for me.
What did he use to mount the center board (on its side) to the bottom board? Did he pre drill thru the bottom piece and then drive screws in to the center piece from the far side or use finishing nails?
I'd like to know what size nails or screws he used. My concern is getting the best bite into the wood, but not split it since I'd be going into the side of the board. BTW, I'm using 3/4" plywood.
Thanks!!
How did your mate mount the square tubing to the side of the drawers?
thanks.
