How about a new tube for the fill hole and just use the overflow hole as your level gauge. The overflow makes getting the level easy and you will only need to check the level when filling. It's getting new oil in that sounds difficult.
I typically like the idea of the overflow except in this case it is only accurate at certain temp range.
After changing atf on both types several times:How about a new tube for the fill hole and just use the overflow hole as your level gauge. The overflow makes getting the level easy and you will only need to check the level when filling. It's getting new oil in that sounds difficult.
I did another drain and fill last weekend this time it went a lot smoother. Before starting, I bought some 1/2" ID vinyl tubing and cut it to about 4-5ft. I dropped one end of it from the hood down - DS side to the floor. I then inserted that end in the fill hole about 3" - the fit was perfect that it would not come off easily with weight of the fluid. I then just pushed/routed the tubing up a bit so that it would not sag. I poured the desired quantity of ATF thru a funnel connected to the other end from the hood. It went down very fast and the tubing did not retain any fluid and no leaks on the fill hole. It was surely a lot easier this time around!
BTW the fluid this time looked a lot better than the first drain and fill.
Cruiser Dan got back to me and he is not aware of the possibilites of swapping the '03 and '05 tranny pan. He said they are different trannys and no dimension specs for the parts.
Tsarte seems to have figured out a system that makes a pan swap unnecessary.
What was " the desired amount" of ATF for a single drain and fill ?
No. The fluid level has to be correct when it's at the operating temp. It's not very complicated to just heat it up and then fill until it runs out through the overflow.would doing the fluid swap cold eliminate the temperature/volume measurement issue
