- Thread starter
- #181
Hitting a brick wall.... don't know about you guys, but seems every project goest through this stage. Frustration level is at about a 9.
- Front driveshaft frozen.
Slip joint won't budge. I've tried heat (MAP gas, glowing red), dry ice freeze, vibration with air hammer, every penetrant known to man. Looking like driveshaft work is going to be required and that wasn't considered in the budget. Not sure if I can salvage the parts and maybe Triangle can repair what I've got. Saving grace is that this would have likely resulted in t-case damage had it not been noticed, and I've got a couple Gs in this case. Silver lining?
- Twin sticks
Major mods now required due to moving the driveline 1.125" towards passenger side (Mark's 4wd kit requirement). I think I have a plan, but it's probably 8-10 hours of extra work. Fingers crossed on this one.
- Exhaust
Looks like the manifolds I purchased won't work for me. I've stared for hours now and don't see a path for the p.s. tube to cross over or exit to the rear. This is different from the 60 guys because I have bellhousing to frame mounts that block that path. Looking at some center dump mani's / headers now:
This will allow me to run the p.s. under the front side of the oil pan and then either 2 tubes to the muffler or y-pipe up front on the d.s.
Not a HUGE problem, but hoping Summit will accept my return of my current manifolds that have been installed, but not run.
- Engine mounts
Using Welder Series as recommended by Stan. Really like them, but I just made a boneheaded mistake and only measured twice and cut once. Apparently, I need to measure AT LEAST 3 times. Replacement part on the way.
Deep breath, step back, and move on.
Ramon
- Twin sticks
- Exhaust
- Engine mounts
Ramon
