While a lot of the tehchnical info about stiffer valve springs etc is generally true, you're talking about a 4000 rpm tractor motor here. I've used a custom ground knockoff of cliffords torque cam and really like it. I got the specs from Mark Whatley, I've got them at the shop somewhere. Not much more lift that stock, but duration and overlaps increased and moved a little to promote better fcylinder fill. I've never upgraded or even replaced the tired old 2F valve springs. But, I don't over-rev the motor either. You cannot think aof a cam as a by itself solution, especially in a low tech tractor motor like a f/2f. You must think in terms of adding compression, carb work, lightening and balancing rotating masses, header and exhaust in a systemic fashion. The idea is to maximze intake flow, cylinder fill, exhasut flow efficiency, cylinder scavenging, etc all at once with all the variables working together as much as possible...
