Doors do not lock when arming RS3000
NaterGator
On Gilligan's Island
Gainesville, FL
This one has me confused.
I searched and saw bpassmore's problem where the RS3000 wouldn't lock or unlock the doors. I tried reseating the connector on the RS3000 module but it didn't help.
Oddly, the disarming of the system does unlock the doors, but they never lock when I hit to arm. This is a new thing as of today; anyone had this happen before? I can manually lock the doors when I get out and then arm the system, but I've been forgetting and walking away with the doors unlocked and the alarm armed. :doh:
This is no good with my DVD/GPS system and radar detector.
I've got same problem before, front driver side, rear passenger side and the hatch wont lock when I activated the alarm.
Replaced the door actuator everything work allright now.
Did it work when you used the switch on the panel by the window controls?
1) Does it chirp when you arm/disarm?
2) Are you sure all doors/hatch are completely closed (dome light goes out) before you try to arm it?
When I bought my rig, the piezo buzzer was dead, so I had to rely on the flashing lights and testing the handle to make sure it's locked/armed....
Once, one of my kids left the right rear door half closed (causing the doors not to lock when arming) and I didn't know until I tried the handle test about 5 cycles later when I did the handle test :doh:
After that, I swiped a piezo from a Tundra and now it lets me know when one of the doors aren't closed fully :cool:
If I lock/ unlock from the inside, sometimes work sometimes dont work.
:hhmm: Mine seems to be working all the time from the door. I guess I'll have to dig into the wiring diagram and break out my multimeter to sort this one out it seems.
It chirps when it feels like it. It does flash though, the single flash means armed and it does this even when the doors don't lock. If you open the door after arming (but without the doors locking) obviously the alarm goes off. It's like everything in the alarm system is working properly except the armed-locking stage :hhmm:. It does lock sometimes, seemingly more frequently when I slam my driver's door shut. No lights stay on in the cabin and the door ajar light goes off.
Ditch the alarm and use your door locks.
Really helpful. No wolf teeshirt for you :flipoff2:
