Some how both of my front and passenger doors have both stopped opening from the inside a day apart from eachother. They will both open perfectly fine using the outer pull, but the inner pull will not release the latch.
I can see down into the latch when using the inner pull, the mechanism that pushes open that latch doesn’t quite move far enough to trigger it to open.
Does anyone know if there is an adjustment to be made like tightening the regulartor / linkage? Or does the latch itself need to be replaced?
