Door stopper/limiters
Toronto, ON
I was wondering, can the "newer" style (slider type) door stopper/limiter can be used instead of "older" style (rod/bushing type) on the 1968-1974 tabs?
I have 1974 and I can't find old style stopper/limiters in good condition, meanwhile I found a few new style ones.
I checked SOR, but the prices are high. My other concern was that the rod will be constantly rubbing on the tub oval hole which would create a perfect environment for the rust to start on.
Any advice is much appreciated. I was driving with Bestop doors so far and don't have experience with metal doors...
anything can be made to fit. You would need to cut out the back of the A pillar to be able to slide the slider in from the back and then drill two holes to mount it. This is probably easier said then done. in my limited experience with the older style door stops (i got the SOR ones but dont remember them being that much...) they did not rub on the paint at all and worked quite well. If you are going to start talking about custom door stops why not just use a piece of nylon strap?
I"ll also add that the holes in the doors for the pin/bolt might be different sizes which could be solved with a small bushing or drilling.
The SOR kit is about $3. cheaper for reproduction old type door stops than for reproduction new type door stops.
There aren't a lot of "perfect environment for the rust to start on" more accessible and easy to treat than the A pillar location of door stops and the old type door stop can be easily enclosed with rubber tubing wherever it may rub so as to allay any further concerns as well as act to reduce any rattle noise resulting from a stop's presence.
SOR sells Door Stop Kit (124-12A-KIT) for $49.07 each. :(
I made some out of a 3/8" bolt and a rubber stopper. Pretty easy if you have access to a torch to heat up the end and smash it flat for the door attachment end. There is an old thread or two on here about making your own.
Does anyone know how to install the door or hood stoppers? I can’t make it fit into the placement hole. Is there a special tool?
Part Number is 9054109151.
Part Name: Hood Stop Buffer (Front)​
Has anyone had experience installing these? They go on the underside of the hood to cushion it when it closes.
@ghong14
This may explain your fitment problem:
Part Number: 90541-09151
Supersession(s): 58368-91601; 90541-09151; 90541-09017; 90541-09139
FOR INSULATOR HEAT; FOR LUGGAGE COMPARTMENT DOOR PANEL.
Fits Corolla, Cressida
You should go to SOR.COM and look at the parts they illustrate for hood pads.
