Door spkr wire into cab ideas
In a van, down by the river
OK, before I am lambasted for not using the search, I did! Spent over an hour looking at stereo and speaker threads, plus all the stuff in the FAQ's. Could not find these details.
Did learn that most folks, for good reason, do not go for the speakers in the doors cause' they will get fouled up from mud etc.
Anyways, how have those that have mounted em' there routed the wire from the door into the cab? Usually there is a hole in the door and a hole in the chassis lined up so when you close the door there is no pinch etc.
I have some ideas in my head, just want to see how others have done it. :cheers:
I just drilled a couple holes and ran the wire through them...I got speakers in all 4 doors.
Reguarding the baffle, I was gonna use a plastic bag. Mostly just to waterproof, well the backs of em'.
I think the speaker face is at risk too, that is why a lot of "wheelers" dont want em' in the doors.
They dont stock the baffle size I would need. Has to be not much over 2" depth and that may be pushing it.
Looks like a good product though...
Incidentally I got all the equipment from Crutchfield and what awesome deals! Free ship to boot.
That is what I'm thinkin...But any problems with the wire pinching?
I'm just pictureing the wire pulling out a bit as you open door, but will it then retract back in...without pinching?
No problem with wire pinching. Drill the holes with a vertical offset (one hole 4 or 5 inches or so above or below the other. Tie a knot in the wire inside the door (just to prevent the wire getting pulled out). Use thick wire (I used that "Monster" speaker wire). Maybe use rubber grommets in the holes, I tried but they didn't last long.
OK can you explain the need of the offset?
Gives the wire more slack and a better angle to flex as you move the door. Prevents the wire from kinking too sharply when you close the door.
Use a "rubber boot" for lack of a better term. This will protect the wire and give it a finished look. Mine came with the power door lock actuators I bought, but any car audio shop should have these available. A so for speakers in the doors you will more than likely need to make a baffle to space out the speaker to get the depth for a good speaker. You also will not want to use plastic bags as the sound wave in the rear of the speaker will make it buzz. Metra make s some plastic baffles the you can cut down and work perfect.
Look into speakers for marine applications. You won't even need the baffles. Some are completely enclosed.
(rant on)Don't cut into old Toyota metal if it's not already cut. Someone will trade you doors with holes already in them. Put them under the dash, they'll work good enough for a cruiser. (rant off)
Here is what I ended up doing.
2-way Infinity 4".
I drilled and ran tubing as a channel for the speaker wire. The tubing fits in push connectors that recess into the drill holes.
Heres are the rears
6x9's Kenwood 200watt. I built the boxes from 3/4" plywood screwed and glued.
Covered with some adhesive backed felt I had laying around.
Looks good Spud! Did you see the recent thread the guy posted that he made ,using fiberglass and bondo then shoot them in candy blue? Also I have been buying from Crutchfield since 1979 . Damn good company to do buisness with!:cheers:
