Door Panel
Discussion in '40- & 55-Series Tech' started by jmode, Aug 15, 2006.
  1. jmode
    jmode
    127
    Apr 8, 2006
    When taking my door panel off, how do i get the window crank and door opener off the correct way? I need to get my old window crank out, which i know is possible. I also need the door handle on the outside and the actual lock where you put your key in. Are all of these able to get out to put into a new door(with no rust :cheers: )??
  2. John Smith
    John Smith In the garage
    4,205
    Media:
    6
    Albums:
    2
    264
    Jun 7, 2004
    Maryland
    You can use a shop rag to pop the clip off the window handle per the manual or use two small screwdrivers to pop it off. Once you remove the inner door panel you can get at the lock cylinder and handle from the backside.
  3. SuperDuperCruizer
    SuperDuperCruizer
    1,182
    Media:
    27
    Albums:
    4
    430
    Jun 24, 2003
    Takoma Park, MD
    A couple plastic grocery store shopping bags work well also...
    Just pull the bag taught & as you move it back and forth, sliding it between the window crank handle and the door panel (be sure to pull both ends of the bag so they are parrallel to eachother)... the bag will catch the clip and pop it off (sometimes along with the window crank). it works great & it's an inexpensive removeal tool.
  4. Pete
    Pete
    387
    80
    May 19, 2004
    You can use the rags or the grocery bags or for less than $5 you can get a tool made just for that. Available at any auto parts store and probably Wal-Mart too. I ground a notch in the handle and use that to remove the clips that hold the panel on.
    Pete
  5. dfmorse
    dfmorse
    1,518
    2
    Jul 7, 2004
    EVERGREEN, CO, USA
  6. AATLAS1X
    AATLAS1X
    7,263
    18
    Jan 24, 2006
    97707
    Pull the clip off with a small dental pic.
  7. oldIron
    oldIron
    448
    1
    Feb 18, 2006
    New Hampster
    This works well and is probably available at any dollar store for a buck.
