Door Lock Actuator - Rubber?
jaymar
SoCal
About to swap in a salvaged driver's door latch/actuator assembly. The rubber bit is in tatters. Any suggestions for replacement (maybe something I can cut to the right shape) and adhesive? Have a few inquiries out on OEM replacement rubber, but I've read you can only buy the whole assembly... Thanks!
Confirmed: OEM replacement rubber not available a la carte.
Rubber what? The O-ring seal between the case pieces?
Large piece of rubber on the outside. You can see remnants in the photo below. Not sure how much rubber there should be, how thick, whether it needs to wrap around the side, etc. Will try to remove the bad one carefully to get a good look. Photo of a brand-new one would also be helpful.
Either way, I'm going to have to make and adhere
the rubber replacement...
It is--but it USED to have rubber or something over it, between it and the inside of the door. Only tiny shreds left. On closer inspection, it appears (based on what look like old glue marks) that it may have been just a narrow strip of adhesive rubber, and that it did run around one side. I was thinking it was a big beefy chunk of rubber. Will learn what I can while pulling the current one out, and have some adhesive stripping on hand. (Then again, maybe it WAS a big beefy chunk, and what I'm seeing are adhesive remnants...)
On the dust/spill sheet under the door panel; will-do, thanks for the tip! Need to get that off to access the latch.
Don't have access to my photos from when I R&R'd the mechanism but IIRC there's a strip of self-adhesive closed cell foam in that location that gets compressed once the assembly is reinstalled. Purpose is to seal off a small air gap between the door frame and the assembly. It runs up the side of the assembly then twists over near the latch as shown in your photo above. You could check out your local Ace Hardware store, they often have a good supply of different widths and thicknesses of foam strips. HTH's.
If that's all I need, perfect. Thanks for the tip. Just trying to have everything on-hand so I'm not driving to the store with the door bungee'd shut... :)
