My second row door will not open from inside or outside, I can hear the mechanism move when i move the handles, but with all my might the door wont open. Opinions? Thanks
GreeeeeeaaaaaatttttOscar, you'll need to get nasty with that door panel and just get it off. Although I didn't completely destroy my door panel in the process, I had ordered a replacement off a part-out before addressing the exact same problem not too long ago. Prior to going that route, I tried all I could come up with to no avail.
You'll also likely need a replacement door switch itself as the internal spring has probably snapped (symptoms you mention were identical to what I had). It is what it is....either live with it for a while or go find some replacement parts off a part-out and get after it. Good luck man....
yesIs the window completely up? Functional?
